Basemap Toggle in Shortlist Story Map
4921
04-10-2014 11:37 AM
EricPollard2
I would like to add the basemap toggle widget to my app created with the Shortlist Story Map template. I have done very minimal customization but I am not sure exactly how to put this widget into my app. I have found the basemap toggle javascript code in the examples area (https://developers.arcgis.com/javascript/jssamples/widget_toggle.html) Can anyone tell me where to put the code to make this work ?
Thanks!
Eric
EricPollard2
The Shortlist template is here --> http://www.arcgis.com/home/item.html?id=d02755cd9d7748b9b46f99e8734273dc
I was able to get the basemap toggle into the application template, but it ended up calling up a new blank basemap rather than working with the specified webmap from the Shortlist configurable template. How do I get the toggle to work WITH the webmap being used by the shortlist template?
Thank you for any help !!
Eric
RupertEssinger
Esri Alum
I found this example of a Shortlist that has a basemap picker added: Oregon Wine Story
