Updating a subset of raster values using ArcMap
2090
5
06-17-2021 01:05 PM
Labels (2)
ManishShrivastav
I have a source raster data set (tif file)  I want to select a subset (cells) of the source raster data, change the values of the selected cells and write the changes values again to the source raster.
How should I approach this in ArcMap.
Thank you,
Manish
JayantaPoddar
MVP Alum
Subset by an area of interest (polygon) or by a range of values?
Think Location
ManishShrivastav
By Area of interest.
JayantaPoddar
MVP Alum
1. Convert the Polygon to Raster . Keep the cell size same as the source raster. Also define snap Raster (Environment) as the source Raster.
2. Use Raster Calculator with a similar expression.
Con(IsNull("Raster2.tif"), "Raster1.tif", 0)
replace "Raster1.tif" with the source Raster name
Raster2.tif with the subset raster name
and replace 0 with the desired constant value
Think Location
ManishShrivastav
Thanks a lot, this worked for me partially. But this creates a new raster masked by the polygon area, my need is that the changes should be made to the selected subset of cells in the original raster and get back the original raster along with the changed values such that the area that were not under the polygon should remain unchanged.
JayantaPoddar
MVP Alum
Raster tools will usually create a new output. Use the above tools in a model builder along with Copy and Delete tools.
*Keep a backup of your source raster before executing the workflow, since the Delete is permanent.
What value do you want to put for pixels falling in the subset area? What other deviation are you seeing from your desired result?
Think Location
