Selecting maximum Value based on other field using ArcPy
6584
13
06-27-2021 08:28 AM
Labels (3)
badrinathkar
I want to populate a field (MaxElv) selecting the highest value from another field (Elevation) based on the Id field (Id). The data looks like this:
Id   Elevation   MaxElv
1     50
1 72
1 83
1 66
2 105
3 27
3 24
2 98
1 46
3 22
2     96
3 26
2 99
4 25
4 21
4 22
3 28
1 52
I have develop the following code:
>>> import arcpy
... fc = 'Country'
... CountryList = []
... with arcpy.da.SearchCursor(fc, ["Id"]) as cur1:
... for row1 in cur1:
... if row1[0] not in CountryList:
... CountryList.append(row1[0])
... for i in CountryList:
... ElevList = []
... where = """{} = {}""".format("Id", i)
... with arcpy.da.SearchCursor(fc, ["Elevation"], where) as cur2:
... for row2 in cur2:
... if row2[0] not in ElevList:
... ElevList.append(row2[0])
... ElevList.sort()
... max_Elev= ElevList[-1]
... where2 = """{} = '{}' AND {} = {}""".format("Id", i, "Elevation", max_Elev)
... with arcpy.da.UpdateCursor(fc, ["MaxElv"], where2) as cur3:
... for row3 in cur3:
... row3[0] = 1
... cur3.updateRow(row3)
But it gives the following error
Runtime error
>>> import arcpy
... fc = 'Country'
... ElevList = []
... ElevList.sort()
... row3[0] = 1
Runtime error
File "<string>", line 20, in <module>
RuntimeError: An invalid SQL statement was used.
badrinathkar
Sir, I don't find any option to delete the post. please guide me.
JoshuaBixby
MVP Esteemed Contributor
I am not sure what is going on because the "Pro" cross-post is not redirecting to this one.  Maybe someone merged the two already.
DanPatterson
I merged them
... sort of retired...
DanPatterson
Summary Statistics (Analysis)—ArcGIS Pro | Documentation
Id is your case field
Statistics field is Elevation with Maximum as the option (or whatever)
skip the maxelev stuff, just join the resultant table back if you need to and persist the join
