Model Builder Error: Switching Selection on Select by Location
2008
03-20-2021 01:21 PM
KWallin
ArcMap 10.7.1 I'm trying to make several Select by Location in Model Builder, and am struggling with getting past my first selection because I need the selection to switch.  I'm also wary that if I make a first selection, is there something else I need to do to have it add to that selection successfully?
I've alternatively tried using the Invert Spatial Relationship checkbox in the tool, but that hasn't worked either.
DavidPike
MVP Notable Contributor
I don't think the initial selection is required.  Would you not just use the Trees and Parcel layers as input into the select by location tool with the 'SWITCH_SELECTION' option to get the selected trees outside the parcel?
i.e. get rid of the new selection step.
KWallin
Not successful this way either...
DavidPike
can you share the tool properties, also these are feature layers?
KWallin
