Hello, I keep on getting the same error message when creating an Address Locator in ArcMap 10.4. Can anyone help? I have already gone through the list below and cannot see what I am doing wrong.
"000042 : Failed to create the address locator. ArcGIS 10.4
The address locator cannot be created.
Solution
Check that you have the following:
Do a quick google search on " esri error 000042" you'll get several returns worth looking into.
That's not giving you much to work with and I don't use the old style locators anymore. You may need to contact tech support and provide them some sample data with which to emulate your workflow.
Can you provide a sample of what you address locator source data looks like - maybe 10 records?
