Is there a similar option in ArcMap like Recode in Erdas?
I am processing an unsupervised classification and I need to correct a few portions of the map (to change their classes).
assignment find shelters in Houston.pdf
<\/HEAD>On Friday, March 8, a guest lesson was given at Christian College De Populier in The Hague. Students worked on Hurricane Harvey. They looked, among other things, at the route this hurricane took and possible shelters in Houston. This assignment aligns with the chapter The climate in the U.S. and India (year 2…
Webinar - ArcGIS for Schools
14-02-2019 On Thursday, February 14, my colleague Tom and I gave a webinar about ArcGIS for Schools. The learning objective during this webinar was: How can you use the possibilities of ArcGIS for Schools to prepare and conduct modern environmental education. A demo of Survey123 was given during this. Enjoy watching!
Adding the Dutch base map
<\/HEAD>When you open the map viewer, you get an English base map by default with a global coordinate system (WGS 1984 Web Mercator Auxiliary Sphere). This blog explains how to add the Dutch base map to your portal.<\/P> <\/P> NOTE: <\/STRONG>If you requested your portal in 2019, the Dutch base map is included by default…
Discover service areas
<\/HEAD>In this simple assignment, students must choose a location for a bakery. There are six locations available, and which location is the most suitable to get as many customers as possible? The assignment can be completed in 45\/50 minutes. The instructions are included in the assignment. <\/P> The assignment can be…
Walking from home
<\/HEAD>In this assignment, students will work with ArcGIS online for the first time. They create a small map showing the area they can walk in 5 - 10 - 15 minutes. <\/P><\/BODY><\/HTML>
Leefbaarheid in foto's.docx
In deze veldwerkopdracht doen leerlingen onderzoek naar tekenen van goede en slechte leefbaarheid. Het is een kant-en-klare opdracht, waar geen GIS vaardigheden voor nodig zijn. De resultaten van het onderzoek worden opgenomen in de volgende webapp: www.tinyurl.com/webgisfotosvanleefbaarheid. Doelgroep: Alle niveau's en…
Livability according to residents.docx
<\/HEAD>In this fieldwork assignment, students research the question of how residents assess the livability of their neighborhood. It is a ready-made assignment that does not require GIS skills. <\/SPAN><\/P><\/P>The results of the research are included in the following web app<\/SPAN>:…
Research in the local environment on water nuisance.docx
<\/HEAD>In this assignment, students conduct research on water nuisance issues in their own environment. They can carry out this research at the end of a series of lessons about water nuisance. In the research, students must apply theory about how water nuisance can arise and about solution measures.<\/P> <\/P> How does it…
Lesmateriaal (voor docenten én leerlingen)
Op de webpagina van ArcGIS voor op School vindt u lesmateriaal, veelgebruikte kaarten en data waarmee u met uw leerlingen met ArcGIS aan de slag kunt. Hier vindt u het lesmateriaal.
Getting started with ArcGIS Online - part 1 (for teachers and students)
In this Story Map, you will learn to work with ArcGIS Online, which is an online geographic information system (GIS) that allows you to create maps yourself and share them. With a GIS, you can gain insight into phenomena in areas. For example, what are the climate and population distribution in a certain area? And what is…
Community Guidelines
<\/HEAD>Welcome to the ArcGIS for Schools GeoNet space of Esri Netherlands! Below you can find more about our mission and the guidelines for the community.<\/P> <\/P> Mission<\/STRONG><\/SPAN><\/P>You are increasingly making better use of the possibilities of ArcGIS for education and finding our content better and better,…
Status en storingen
ArcGIS Online status Via het ArcGIS Online Health Dashboard is de status van ArcGIS Online te bekijken.
Aan de slag met GeoNet
Om zoveel mogelijk uit GeoNet te halen raden wij u aan om de onderstaande stappen te volgen. Alle stappen staan individueel ook uitgebreid beschreven op de GeoNet Resource Hub. Stap 1 - Volg de ArcGIS Content GeoNet-ruimte * Om aan de slag te gaan in de GeoNet-community is een account nodig. Klik hier om een account aan te…
Welcome to the ArcGIS for Schools forum!
<\/HEAD>GIS can support education in many ways. GIS stimulates geographic thinking, supports the collection, visualization, and analysis of fieldwork data, and can be used as a presentation tool in the form of StoryMaps. <\/P> <\/P> This forum is for all teachers who work with GIS, want to work with it, or are simply…
