Updating ArcGIS Viewer for Flex
921
07-22-2014 11:13 AM
GeorgePapamihalakis
I am going to be upgrading from 3.3 to 3.6 soon. If I upgraded the main application, but not the viewers/widgets at first, would everything still function until I upgraded the viewer? The reason I ask is that I have a bunch of viewers configured a certain way and I wouldn't want to break all of them at once. So Id like to tackle each one individually until I finish them all. I seem to remember it being that way but I don't remember for sure. Thanks
AnthonyGiles
Honored Contributor
George,
if you create separate instances of your applications under a different folder the you should be able to upgrade without effecting your current applications then once you are happy swap them over.
you are best to upgrade both your application and widgets to the same version at the same time, running old widgets could cause problems.
regards
Anthony
AnthonyGiles
Honored Contributor
George,
regards
Anthony
GeorgePapamihalakis
Yeah, turns out all of the applications/widgets work until you upgrade them. So I was just creating duplicates, configured them and then replaced the old applications with my new ones.
