Field Names in New Feed - Setting up Schema
Brand new Enterprise Velocity user here! Coming from GeoEvent, I want to confirm something that I cannot nail down in Velocity documentation…. When I am creating a new Feed and have a number of nested fields that I am flattening, the Names of those fields are coming out longer than 31 characters long. If I were to modify…
Two seperate Velocity RTAs crashed this evening
Just wondering if anyone else had a simular issue with unCaught exceptions in RTAs crashing about 1730 EDT today.
ArcGIS Velocity 12.1 On-Prem – Who is supposed to manage the STBDS “black box”?
We are evaluating ArcGIS Velocity 12.1 for ArcGIS Enterprise as a replacement for GeoEvent Server in an on-premises environment, and one area is currently unclear: how Spatiotemporal Big Data Store storage behavior is actually managed in production. With GeoEvent Server, administrators had fairly explicit control over…
Allow multiple instances of the same existing feature layer as Output in Real-Time analytics in Velocity for Enterprise
Both GeoEvent and Velocity have processors, which can be used as elements of conditional logic, e.g. filters or "Choice" in GeoEvent and "Route by Expressions" in Velocity. However, GeoEvent allows using the same feature class as output multiples times, which gives possibility to use it in multiple parallel logical…
Add TCP (Server) feed type to ArcGIS Velocity for Enterprise
Currently ArcGIS Velocity has only TCP (Client) feed, as GeoEvent Server has both TCP client and server capabilities. This represents a functional gap between GeoEvent and Velocity, which creates additional complexity for organizations migrating existing implementations. Business case would be that most Dragino IoT/LTE…
Update ArcGIS Velocity for Enterprise Feed Token via Python
In ArcGIS Velocity for Enterprise, an HTTP Poller feed may be configured with a URL that includes an API key. Because API keys can expire after a period of time, ranging from minutes to days, the key must be periodically regenerated. Rather than manually editing the Velocity feed each time the API key changes, you can…
Velocity Enterprise
Working on moving a geoEvent RTA to a Velocity RTA. geoEvent Choices <--> Route by Expression. In Velocity, Route By Expression does not always work, specifically if you turn on the Otherwise parameter instead of specifying all possible filters (I saw this in the Online environment as well). Additionally, all outputs must…
Utah DOT Modernizes Winter and Street Operations with ArcGIS Velocity
Street sweeping and snow operations happen months apart, in different seasons. The Utah Department of Transportation (UDOT) uses ArcGIS Velocity and ArcGIS Solutions to bring vehicle, weather, and operational data into a shared real-time view, helping teams monitor and manage operations throughout the year. From winter…
Geoevent Point Logging Parody
I am trying to achieve parody with Geoevent Server so we can migrate fully to Velocity for Enterprise(12.1). The lack of a geotagger is really causing a problem for me. The issue I am having with Velocity is the join keeps logging points every 10 seconds(source refresh rate) despite the join criteria being set to 'enter'.…
Add Grid Transformations files to Velocity Install
I see that Velocity install does not have grid transformation files Are they going to be added to improve spatial accuracy when doing datum transfomraitons?
Real-Time GIS at the 2026 Esri User Conference
Are you headed to #EsriUC2026? We have a had a busy year and you don’t miss what’s new in real-time GIS. From applying real-time analytics and real-world examples to migration strategies, we’ve rounded up key sessions, live demos, and showcase details to help you get the most out of ArcGIS Velocity and GeoEvent Server.…
What's New in ArcGIS Velocity (June 2026)
Last week’s ArcGIS Velocity release introduced expanded support for new data providers, new analytic tools, enhancements to outputs, and many improvements in overall usability, quality, and accessibility. Key highlights: * New feeds from partners like Dataminr, Samdesk, CompassCom, and Raven Connected -- bringing…
ArcGIS Velocity Configuration Issue - Portal Inaccessible Unless Velocity URL is Added to Allow Origins
Hi Team, We are facing an issue while configuring ArcGIS Velocity in our ArcGIS Enterprise environment. "Portal for ArcGIS is currently unavailable or inaccessible. Please check the connection and try again later. If the problem persists, contact your system administrator" Portal for ArcGIS and Server both are working…
ArcGISVelocityFeed.Service Crashed, Hosted Feature layer Feeds Stuck in Initializing
I am working with point datasets in the hundreds of thousands of records, which I published as hosted feature services and registered as feature layer type feed. There are three such feeds of this magnitude registered on Velocity site. These feeds remain stuck in the "Initializing" status indefinitely; they cannot be…
Here we go again -- June 24th Upgrade
Your ArcGIS Velocity subscription will be upgraded during our June 2026 product release on June 24, 2026, at 10:00 PM PT. You will receive a notification as soon as the upgrade is complete. Please restart your feeds, real-time analytics, and big data analytics at your earliest convenience to apply the latest updates. If…
Error in ArcGIS Velocity log: Tanuki Software
Should I be concerned about this warning in the Velocity log? \ArcGIS\Velocity\bin\wrapper.log INFO | jvm 1 |2026/06/17| Wrapper (Version 3.2.3) http://wrapper.tanukisoftware.org INFO | jvm 1 |2026/06/17| Copyright 1999-2006 Tanuki Software, Inc. All Rights Reserved. INFO | jvm 1 |2026/06/17| INFO | jvm 1 |2026/06/17| INFO…
Can ArcGIS Velocity OAuth use a plain-text (non-JSON) bearer token on an HTTP source?
I'm setting up an HTTP source in ArcGIS Velocity (ArcGIS Online) and trying to configure OAuth against a third-party API. The token endpoint takes a GET with a Basic auth header and returns the authorization token successfully — HTTP 200, valid token — but it comes back as a bare bearer token with Content-Type text/plain.…
Please add support for direct device-to-platform connectivity without requiring an intermediate MQTT broker in ArcGIS Velocity for ArcGIS Enterprise
With the increasing adoption of IoT devices that support MQTT for data transmission (for example, Dragino NB‑IoT MQTT configuration General Configure/Commands to Connect to IoT server for -NB & -NS NB-IoT models - DRAGINO), it would be valuable for ArcGIS Velocity for ArcGIS Enterprise to support direct device-to-platform…
Support spaces for attribute names from input connectors in Field Mapper in ArcGIS Velocity for ArcGIS Enterprise
Currently, certain characters in field or table names are not supported for field mapping, specifically "... spaces, hyphens, and other special characters," but sometimes data schemas from IoT devices have spaces in field names, for example:…
Add UDP Input Connector Support to ArcGIS Velocity for ArcGIS Enterprise
With the planned retirement of ArcGIS GeoEvent Server following the ArcGIS Enterprise 12.3 lifecycle, users are being directed to adopt ArcGIS Velocity. However, ArcGIS Velocity currently does not support UDP-based data ingestion, such as the “Receive JSON/Text from a UDP Socket” input connector available in GeoEvent…
ArcGIS Velocity is now available for ArcGIS Enterprise
ArcGIS Velocity is now available for ArcGIS Enterprise ArcGIS Velocity has been Esri’s real-time and big data processing and analysis capability of ArcGIS Online that enabling users to ingest, visualize, and analyze spatial real-time and big data to gain new insights and take action. With the release of ArcGIS Enterprise…
Refresh Token Errors in RTA's
In all of my RTA's as of last night, I have gotten Refresh Token errors. The only way to correct this is to stop the RTA and restart it manually. Is this normal and why wouldn't the system be able to refresh a token on its own? Even using this method didn't solve the issue:
Add Bearing attribute to Geotab LogRecord Connector
Please enhance the Geotab LogRecord Connector so that it pulls the Bearing attribute from Geotab. The documentation (Link) mentions bearing as a value that is pulled, but the table further down in the documentation is missing the bearing value. And after testing the connector, I can verify that bearing does not appear on…
Velocity Geotab Feed Errors
Is anyone having issues with the Geotab Feed for Velocity for ArcGIS Online? We started having issues with ours on Friday & Saturday. If I start the feed, it pulls in the initial set of data fine, but then each request for updates after that is returning the following error: "Unable to parse DeviceStatusInfo data." I have…
RTA Doesn't Complete with No Error Logs
I have an RTA set up to watch a feature layer feed (which uses survey123 to create data). I had a trigger this morning, and the feed logs detected it (like it shows it found 1 feature at that timestamp 10:31 AM CST)... but it looks like the rest of the RTA just didn't run, and there's no errors at that time or any other…
