Hello Everyone,
Currently my Planning department is looking into using ArcGIS Urban to visualize/include Current, Proposed, and Under Construction developments with 3D Buildings. They would also like metrics viewable in some form of a pop up menu (or side bar like Urban). Our organization has Current 3D Buildings and I intend to coordinate with said planning department to receive CAD files or 3D files and use FME to extrude/create/update our 3D Buildings dataset. Ideally, there will be an attribute in there that distinguishes them between their status.
This is where I am running into a bit of a dilemma. I have learned a lot more and no longer have Trial access to Urban so I am in need of assistance from users.
My planning department is not intending to use the "create buildings" option in Urban, nor are they interested in using the planning/zoning feature. They're primarily focused on the visualization + metric tracking. From my understanding, you can only use the metrics and custom metrics if you have space use types allowed correct?
These are the Metrics they are interested in which are all tracked in an excel document currently:
• Development (general footprint, height, storeys, density (FSI)),
• Population (number of residents, density),
• Housing (number of units and unit type, if possible),
• Affordable housing units,
• Servicing allocation, and,
• Employment (anticipated jobs).
Currently, I am just unsure how Urban would work because if I have a backend process update our 3D buildings, they will not be interactable with Urban correct? I could only colour code them based on that STATUS field (current, proposed, under construction) as a context layer. Or would I use them as an indicator which then would allow me to use the metrics?
I am just casting a lot of doubt on if Urban is the right tool for our planning department and I am hoping someone else can help me grasp it a bit better/faced a similar concern.
Kind Regards,
Senad
