I am trying to use the Urban API but I got authentification error:
GraphQL query failed with 1 errors
[{'message': 'The access token provided is invalid or expired.', 'extensions': {'code': 'UNAUTHENTICATED'}}]
Im not sure why the token provided to the urban api url is not working because it was generated using arcpy like below:
import arcpy
from sgqlc.operation import Operation
from sgqlc.endpoint.http import HTTPEndpoint
from urban_api_schema import urban_api_schema as schema
arcpy.SignInToPortal("https://www.arcgis.com", "myUserName", "MyPasswOrd")
#token is generated correctly
token = arcpy.GetSigninToken()
urban_api_url = "https://urban-api.arcgis.com/graphql" + '?token=' + token['token']
endpoint = HTTPEndpoint(urban_api_url)
#here it's the function that call the api to update the parcels
for parcel_chunk in parcels_chunks:
op = Operation(schema.Mutation)
create_parcels = op.create_parcels(urban_database_id="1c80e3e815594fd288d347e132138f0a", parcels=parcel_chunk)
create_parcels.attributes.__fields__('global_id')
json_data = endpoint(op)
errors = json_data.get('errors')
if errors:
print(errors)
