ArcGIS Urban Time Zone
222
09-04-2025 02:07 PM
sonia_ml
Can anyone please help me to set up the Time Zone in ArcGIS Urban?
The shadow studies are not accurate so far. Nor sure where to set up the time Zone. The model is properly geolocated.
Thank you!
Sonia
Till_Schmid
Hi @sonia_ml
The time zone is automatically detected by the widget based on the camera location. In some situations this might not be accurate. You can change the time zone in the shadow cast analysis by clicking here:
This will open a dropdown:
The time zone will then be stored in the analysis for when you next run the analysis.
I hope this helps!
Best,
Till
Till_Schmid
Hi @sonia_ml
I hope this helps!
Best,
Till
sonia_ml
Hi Till,
Thank you!
