[Updated July 2023: Added new note with link to a more recent and complete video]
Note: You may want to watch this video instead for a more recent take at this functionality
Just a few days a new Create Report action was added to the ArcGIS Survey123 connector for Microsoft Power Automate. While this action will not be officially documented or supported until the upcoming February 2023 release (currently planned for February 22), you can start playing with it now.
The video below will give you a quick tour to get you going. Enjoy!
If you have any feedback, please let us know by posting a comment below or adding your comments to the Survey123 Early Adopter Community website.
Note: Since this action was added to the connector, some of you have reported that any flow previously authored from a Microsoft Power Automate template, stops working when you edit it. To resolve this issue, the Survey123 connector needs to be deleted from your flow and added again. We are working to understand if this problem can be prevented or not.
Cloudpoint Geospatial found a workaround for that. Works great for us!
https://cloudpointgeo.com/blog/2024/6/27/how-to-avoid-expired-tokens-for-arcgis-connectors-in-power-...
Bonjour à tous et merci pour ce post,
I have a problem with the URL. It worked once with .doc but nothing with PDF. However, the report is created correctly in Survey. I have this error message "The sourceUrl provided is not supported ". Can you help me ?!
