When making a report from 2 records a repeat section in a conditional report element is causing an error "The task failed because all reports failed to run printIndividual." I'm quite sure this is what's causing the error since I tried generating a report where the repeat section is outside conditional report element and it would work.
On the attached word document below, what I'm trying to achieve is basically a template for a before and after picture with details of a location, and I'm hoping for the repeat to show 2 images in one page from 2 different records. Which works for the first 4 pages but when it gets to the 5th page where it's in a conditional element, it gets an error.
