View survey Via URL in Portal
561
05-29-2020 04:20 PM
Milton
In Survey123 in AGOL I can create a link that will allow a user to look at a specific survey in the surveys format.  The link looks like this: https://survey123.arcgis.com/share/thisIsARubbishid?mode=view&globalId={RubbishGlobalID}
I want to do the same thing for something in portal.  I have a URL that looks like this but it brings up a blank Survey to fill out.  https://survey123.arcgis.com/share/thisIsARubbishid?mode=view&globalId={RubbishGlobalID}&portalUrl=h...
I think I am dang close and either this is not supported or I have to tweak my URL.
Thanks in advance!
Shwu-jingJeng
Hi Milton,
Fre things you might want to check here:
1. Please check the version of the survey and make sure it's 3.9 or newer
https://community.esri.com/groups/survey123/blog/2020/02/19/upcoming-changes-to-survey123-web-forms-...
2. For the URL like , try &mode=view, instead of ?mode=view, like the below one.
https://survey123.arcgis.com/share/thisIsARubbishid&mode=view&globalId={RubbishGlobalID}&portalUrl=h...
