Survey123 Report with Map displaying points relevant only to that survey submission
1247
05-22-2024 03:53 PM
j-bromp
I am trying to create a survey report containing a map that displays the geopoints collected in a survey. So far I can create the report however all of the points in the layer on the web map are displaying. As a note, the geopoints are contained in a repeat.
I am trying to play around with the summary section however I keep getting errors about end nodes being in the wrong place etc. I am hoping to filter the points by creation date as shown in the snippet below.
I was thinking maybe a need to have a new web map that shows a filtered version of the points via SDE? I haven't really played around with that so not sure of the capabilities.
Any help would be much appreciated.
Melissa
Hi @j-bromp , there is another post that goes into this in a bit more detail and has some partial solutions, but no complete successful solution yet: https://community.esri.com/t5/arcgis-survey123-questions/survey-123-feature-report-filter-map-using-...
