Survey123 Field App Inbox Map - How do I add a Legend?
545
02-03-2025 03:43 PM
MollyBurton
My team and I utilize multiple color and symbol options regarding survey points that show up in the Inbox map view in our current work process.
We would like to add a legend to the map for our users, but don't see any options to do this. Is anyone aware of a way to add a legend to the Survey123 field app Inbox map?
ToddW_stl
I'm not sure about that... Is there anything preventing you from using ArcGIS Field Maps to edit the data instead?  You can view the legend there (see #5: Overflow under Map and panel section of Field Maps docs).
ToddW_stl
If you must use Survey123, a workaround could be to use labels to display what the different colors/shape intend to indicate.
MollyBurton
Thanks for the reply @ToddW_stl. We currently use labels and instance name color coding/status filters in the inbox as well. We utilize Survey for multiple rounds of fielding and the complex relevant logic/calculations we're able to build in. We have tried Field Maps, but it isn't as good of a fit as Survey is for us at the moment (we're focusing mainly on filling in information for points already placed for the user with some pre-populated data, rather than having them placing features on the map and then collecting the information).
I was mainly checking in this forum if we're missing something obvious in Survey regarding the legend before posting this as an idea in the Survey123 ideas forum.
