Survey123 create ability to include media URL attachments as an attribute in CSV download:
When using media data generated in the field by Survey123 (e.g. georeferenced photos), the media is visible in the map pop-ups created in Survey123, but is not visible if the data is exported as a CSV.
It is very desirable to be able to use the data as an exported CSV because the data can be reconfigured and additional attributes added as columns e.g. re-visits to fieldwork site; data from others about the same locations. This is particularly the case for educational uses, but almost certainly would apply to a wide range of other use cases. The reconfigured CSV can then be uploaded as a Feature Layer which can be used and updated in the usual ways. This would make Survey123 an even more powerful tool.
Suggestion:
Enable the CSV creation process in Survey123 to create an attribute column for Image_URL (or for more than one image, Image_URL_1, Image_URL_2 etc)
