survey results show html tags in print/PDF export
1308
08-28-2017 01:22 PM
Lake_Worth_BeachAdmin
When viewing the data submitted in a survey.... the results show the html tags used. see image below....
how do I disable this or is this a bug?
However not all the fields with html tags are being show with the tags. see the xls form.... circled in reg (shows the tags)
yet the list below it does not (see other image value circled in green)
Tags (4)
JamesTedrick
Esri Esteemed Contributor
Hi Joe,
Currently, the Survey123 website doesn't expect HTML to be embedded in the answers provided.  I've added your experience to the development issue concerning this.
The html tags are also displayed in the Feature Service in AGOL, which means even though I want my survey styled nicely I have to remove my tags because I dont want my clients to see the tags in reports/web maps.
ZhifangWang
Hi Joe,
Before we have enhancement to display the html tags directly in individual response, would you mind to try out our new report feature? https://community.esri.com/groups/survey123/blog/2017/07/26/introducing-custom-form-report-templates...
I think the report feature can fulfill your need too.
The custom report forms (print layouts?) they still show the html tags as well.
