Survey 123 feature report - filter map using global id
10630
23
08-27-2020 04:40 AM
RABConsultants
I have a survey which surveyors use to complete property flood measure surveys. One part of the survey is a repeat that includes a geopoint question where the surveyor marks the location of each measure to be applied to the property. Usually each property will have 10+ measures. This all works as intended.
I am having trouble creating a map within the feature report that shows each properties measures but not the measures of the nearby properties. I have added in the feature layer and saved it as a webmap and called that within the feature report. Is there a way to filter the webmap within the feature report to only include the measures that relate to that survey? Perhaps some filter using the global ID can make this possible?
j-bromp
Just updating this thread, you can achieve this using python by removing all layers from the webmap then re-add your required features. if the features are held within a repeat you can query the feature layer to find the parent row with the most recent global id, then find all repeat features that share the same parent row id and re add them back to the webmap. this will show only the features relevant to your most recent submission. you then trigger this by survey submission.
ZhifangWang
Hi all,
The new `$map` keyword, which allows you to print a web map without referencing a survey question, and the `mapFilters` method, which filters features in operational layers in a web map, are now available on the Survey123 Beta website. For more details, please refer to this EAC document. As this is currently a beta feature, any feedback would be greatly appreciated via the forum on EAC.
RABConsultants
Any update on how to show all the geopoints inside the repeat of a selected parent record without showing other unwanted survey geopoints that need to be filtered out of the map?
So far my map settings just show all points related to the parent layer. How would I change this to work:
mapSettings: “ec336c1b4e8b4e7a83f22969ad751eca”:425 | size:700:450}
ZhifangWang
Hi @RABConsultants ,
There is a new method mapFilters in report template to filter out features in a layer in web map. Please see  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-print-web-maps-in/... and let me know if this could help with your workflow.
