Sort results of select-multiple question
1868
02-09-2022 05:08 AM
HélèneTouyéras
Good afternoon Survey123 friends!
When using a "select-multiple" question in Survey123Connect, the list of values is filled as the user selects values: value are ranked using their selection time/order.
Is it possible to sort the resulting list using the value names?
In the example below, I would like the result to be a 'simple' 1,2,3,4,5.
Many thanks for any help and pointers! 🙂
Best wishes,
Hélène.
DougBrowning
MVP Esteemed Contributor
DougBrowning
HélèneTouyéras
I would do... but I cannot (probably because of the status). I will comment with this question, though ... and upvote whenever the idea is open for it.
Thanks for the fast reply! 🙂
