Redirect on Submit Using Survey123 Connect
568
03-11-2024 04:45 PM
AnthonyCastelletto
I'm using Survey123 Connect to design my survey. I'm doing this because I want to send the input to a specific web map. It does not look like the web design version of Survey123 will let me do that. At any rate, when the user hits submit, I would like to redirect them to a specific url. I don't see a way to do this in Survey123 Connect. At least not explicitly. Is there a workaround or any other kind of method to redirect users to a new website when they submit their responses on the foirm.
abureaux
MVP Frequent Contributor
This is now available on the beta website https://survey123beta.arcgis.com, where you can define the thank you screen content in the XLSForm with dynamic labels  by using a note question named `generated_note_prompt_submitted`, please see the EAC documentation for more details: Define Survey Elements for the Web App in Survey123 Connect. Any feedback is appreciated.
This feature will be available in the mid-December update for the Survey123 web app.
Original post here by ZhifangWang in 2020.
