Read-Only Questions Look Editable
2574
02-27-2024 06:24 PM
MappingMoose
Hi all,
When configuring read-only questions in Survey123 Connect a lot of the time they look like they are editable because they still display what looks like a response field under the question (ever so slightly greyed out box).
I've found I can prevent this by setting the appearance to compact if it is an open text field or by using note fields and hiding the actual fields etc., but I was wondering if there's a simpler way to go about it for non-text questions like integer or decimal?
abureaux
MVP Frequent Contributor
Not that I am aware of. Drop-downs are (visually) also bad for that since the drop-down remains.
In the end, so long as items are not editable, I try not to worry about it.
You can always submit an idea that "read only" items are visually consistent/obvious. This has been something that has crossed my mind several times in the past.
DougBrowning
MVP Esteemed Contributor
I think one of the reasons for this was so copy/paste is not blocked on these fields.  I had requested it long ago I think.
MappingMoose
I have found that with either presentation of the read only question, copy/paste is blocked on both the mobile app and the desktop app. It does allow highlighting of the value, but nothing further.
DougBrowning
Well yep can no longer copy.  Bummer.  I do not think there is any way to make it different unless you change to a note type.
JoshConrad1
I needed to have a readonly date field appear in my form with the intent of hosting a web map as an element in an experience builder map that integrated survey123 into the map's popup. the form was developed using Survey123 connect, and when i would test it as desired (thru Experience Builder) the date field was still editable. I finally got the date field to be uneditable by configuring my date field in survey123 as described below:
1) create a date field type
2) set appearance to Hidden
3) set readonly to YES and default to "today()"
then created a new text field type - set it to required and read only and set the entry in the calculation column to format-date(${date_field_name},'%m/%d/%Y'). solved my issue.
hope this methodology works for others trying to do something similar with different field types!
