Hi all,
When configuring read-only questions in Survey123 Connect a lot of the time they look like they are editable because they still display what looks like a response field under the question (ever so slightly greyed out box).
I've found I can prevent this by setting the appearance to compact if it is an open text field or by using note fields and hiding the actual fields etc., but I was wondering if there's a simpler way to go about it for non-text questions like integer or decimal?
