I go to publish a survey from Survey123 Connect and because I'm using a submission_url, I get the error about missing fields. Can I export this somehow? I just want an easier way to share what these 47 fields are to my team so we can get that schema updated. The Analyze results don't include this info in a handy table. Just seems like getting these results in an exported table would be easy. You can't even select the content and copy it out. Maybe I'm missing something. Help?
The reason you are getting this error is because you are trying to build a survey from an existing feature service. You are trying to create new fields in a feature service that was created outside of that form, which is not allowed. Since the analyze results aren't helpful, I'd look at that error list and copy the matching names in the name column of your xlsform to a new spreadsheet to send over.
Yeah, glad you mentioned this because I like easy buttons. Thanks!
One trick is to give Connect the service URL and let it build a form for you. Then at least you have both in Excel format.
Appears there is no straightforward way.
A workaround, publish without the submission url, open the resulting feature in ArcPro. Open attribute table, open the fields menu, select all, copy and paste in excel.
here is some other thoughts:
https://community.esri.com/t5/arcgis-survey123-questions/printing-the-schema-section-from-the-survey123/m-p/1602115
Signed in members can post, follow updates, and more. New here? Register a free account.
