Printing the schema section from the Survey123 Connect app
301
04-02-2025 08:03 AM
SusanWS_nysm
Good morning!
This is truly not a critical problem, but I am curious if there's a way to print  or export the schema section directly from the Survey123 Connect -- or a workaround others have discovered. I think this section is well-composed and clear in appearance and would make a good addition (as an appendix) to a report I'm writing.
Layers | Fields | Field Properties
(field properties are shown for the layers and fields highlighted in blue)
The only option I see available is either printscreen and editing the images or doing screen grabs with tools like SnipIt.
Thank you in advance!
Susan
@IsmaelChivite
DavidPike
MVP Notable Contributor
No simple way I can see.  You can see the .xml schema in the survey folder (Files icon in the LHS tab) but that's not very friendly as you'd want to parse it into something more readable.
Same goes for downloading the gdb and exporting the xml workspace document.
the fields option of the data tab in ArcGIS online might be an easier screengrab.
I think the cleanest option is looking at the data from the hosted feature layer in ArcGIS Pro and right click - design - fields.  that should be a nice clean view although not all the survey123 relevant info is there.  You can also select all and export to Excel etc.
DavidPike
SusanWS_nysm
Thank you David!
