Overwriting time question when cycling through repeats
664
14
05-15-2024 06:09 AM
GeorgeClutterbuck
New Contributor III
Using survey123 connect I have created form containing repeats which contain a time field. If I cycle through the repeats once filled out, the time field for all the repeats change to the most recent entry. I've tried using the once( function and changing the bind parameters to manual calculation and this works fine before publishing the survey on desktop, but the error perists on the field app and post submission. Any thoughts?
Thanks.
DougBrowning
MVP Esteemed Contributor
Is there any kind of if statement connected to this date field at all?  Anywhere in the chain
abureaux
MVP Regular Contributor
My suggestion: Try again.
3.20 was rolled out this week (I just got it today). I am super certain that I saw a bug report for "date and time values in repeats being reset" marked as fixed for this release, but I can't find the post to confirm...
RobertAnderson3
You did indeed, it mentions BUG-000165769 - dateTime values overwritten when navigating through repeats.
What's new in ArcGIS Survey123 (June 2024) - Esri Community
As of release 3.20 Survey123 on June 24, 2024 this issue should be resolved.
abureaux
That's the one!
MatthewDesjardins
New Contributor II
Thanks, that does seem to have resolved the issues that I was seeing!
