Map report with all the geopoints (repeats)
2872
6
11-19-2020 08:46 PM
HaroldHerrera1
Hi everyone!
My question is about the map created in reports.
How can I configure in only one map, all the geopoints that repeat question created. I need to create a map showing all the points created by the geopoints of the repetitions, as a summary map of where the survey was made,
It's possible? Any idea?
2 Solutions
JamesTedrick
Esri Esteemed Contributor
Hi @HaroldHerrera1 ,
You can create a web map with the repeat data and reference it in the report when generating a map, however this will show all points (not just the repeats related to the parent record in the report).  Having a map automatically show just the repeat values isn't supported at this time; you may want to add this as an idea to consider as a future enhancement.
ZhifangWang
Hi @PaulLewis ,
Yes, the above EAC doc is not available now since the feature has been released (out of Beta and EAC). You can refer to this help topic https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereportqueries.htm for details (find "map" in the page).
JamesTedrick
BenBaker1
Hi @JamesTedrick , your solution may be what I'm looking to do in a post I just replied to  before I saw this thread. I'm having trouble with the syntax of adding a web map to the report that is not linked to a survey. Can you expand on that?
HaroldHerrera1
Hi @JamesTedrick
Correct, we create a map showing all the data included in the feature, but not only the repeats. I will report this for future enhancement.
ZhifangWang
Printing multiple records on a single map is now available to test on the Survey123 beta website and will be supported in the coming 3.14 release in late February/early March. Please see this EAC doc for the detailed syntax.
Thanks again for your feedback!
PaulLewis
Hi @ZhifangWang I can't get access to that document you've provided a link to. Has this been removed?
ZhifangWang
Hi @PaulLewis ,
