Is it possible to copy answer from one survey submission to another using Survey123 field app?
2258
10-31-2022 02:28 PM
Katie_Clark
Hello,
I am wondering if it is possible for users to copy a sent survey using the Survey123 field app, so that they only have to change a few fields in a complex survey when most of the data is the same to the one they just submitted. I've seen this post which says this can be done using the web version (I even commented on it a long time ago, but didn't receive a response) but I'm wondering specifically if this is possible to do in the field app?
I've tried using the "Favorite Answers" method but I haven't gotten it to work like I had hoped for this functionality...
Thanks!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
2 Solutions
DougBrowning
MVP Esteemed Contributor
If you go to the sent box you can copy into a new survey right there.  Is that what you mean?
Katie_Clark
Apologies, Doug. I answered my own question - I hadn't noticed this option before but now I see it right in front of my nose...
One of those days, I guess.....thanks for your time.
Cheers,
Katherine
Best,
Katie
DougBrowning
Katie_Clark
Thanks Doug, I see that functionality when accessing through the "Sent" box as you mentioned. However, almost all of my surveys use the "Inbox" feature instead of the "Sent" feature, and I know it's not recommended to have both enabled at the same time.
Do you know if it's possible to do this while using the inbox feature? I tried but it seemed like I could only edit the existing survey.
Best,
Katie
DougBrowning
No sorry I do not know.   I think editing Inbox surveys is way too dangerous so I never do it.  I prefer 1 for per visit.
Katie_Clark
Cheers,
Katherine
Best,
Katie
