I just started exploring URL parameters on survey 123. My goal is to be able to prepopulate the form using an existing record. I have been following the below three posts. However, I am very new to this and got stuck in locating the global id of the survey record that I just submitted.
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-web-form-url/ba-p/894722
https://community.esri.com/t5/arcgis-survey123-questions/method-to-to-copy-data-from-an-existing-survey/td-p/1005629
https://community.esri.com/t5/arcgis-survey123-questions/duplicating-survey-editing-records-in-a-web-form/m-p/797404#M9763
Can anyone point me to the right direction?
Thank you.
First, take a peek at the fields for the hosted feature layer by opening the item detail page > Data > Fields. Click the 'Display Name' header if you have a lot and would like to sort alphabetically. Do you see GlobalID there? If so, you're on the right track: open up ArcGIS Pro and add the the layer (Add Data > My Content). From there, you should be able to see all hidden attributes, including GlobalID.
