How to add the capability to drop a point anywhere on a Survey123 map?
768
10-27-2024 03:59 PM
NiColahh
We are trying to push out a Survey123 app for public use but would like to add the capability to drop a point anywhere on the map embedded in the survey instead of allowing location services to capture the location (e.g. https://survey123.arcgis.com/share/b1342f14e2a747298016240971f8ff61).
Is there an easy way to do this? I haven't configured the app for offline use since this will be pushed out to the public and needs to be as simple as possible. However, some areas where data need to be collected will not have internet service...so, we need a way to capture data in those areas. We can push out a more robust offline-capable app to GIS users for that if needed, but I'm looking for a way for the public to capture these locations as well--I think having the capability to drop a point anywhere on the map (like the above example) should help with this but I'm open to other suggestions too.
Tags (1)
SimonSchütte_ct
MVP Regular Contributor
