Custom Geopoint Icon in Report Maps?
639
05-01-2025 03:20 PM
JeremyMulcahy-Hill
Curious if there is a means of using the custom geopoint icons in report maps that aggregate points done in the survey. While the custom icon displays in Connect and Field App, web I know is a missed opportunity, with that said, does this also trickle down to reports as well? Would there be a way to store said custom icon for a repeating field in a calculation for a media field and then use that in lieu of the default pin. OR are the only icons that is applicable to are the doticons that ESRI hosts themselves?
ZhifangWang
Hi @JeremyMulcahy-Hill ,
Do you mean the Survey123 feature report? If yes, you can use the syntax drawingInfo to customize the symbol on a map.
Links may help:
