Collect geometry from GPX file
1242
04-22-2021 10:09 AM
GuidoSitta
Hello, I would like to create a survey where people can add on the map the way track from a gpx file together with some images and description of their activity. The feature layer that contains the survey record should create a new geometric feature from the GPX file uploaded by the user. Is this possible?
Thank you all!
Ciao
Jim-Moore
Hi @GuidoSitta the functionality you describe is not currently possible with Survey123 and isn't in our timeline to support. However, if it's something you would like to see included, you could raise it as an idea on Esri Community or submit an enhancement request via Esri Support. Similar requests from other customers can then be attached to the same request, which helps us assess demand for the enhancement and prioritize it accordingly.
Best, Jim
Jim-Moore
Best, Jim
