Can I add "extra" labels to a range question in Survey123?
1008
12-29-2021 11:58 AM
McCarthyBrianDEC
A user has requested "helper" labels on range questions like those below - additional numbers under intermediate ticks (for example, four new labels at the multiples of 20).  I have not found a way to label anything other than the start and end values; I see that there are darker ticks at 25, 50, and 75, but that's only a small boost, and as the bottom range shows, they move around when a value is selected!
I would accept any method that achieves this - appearances, parameters, scripting, etc.  Any suggestions?
Thank you -
Brian M.
Kanin
by Esri Contributor
Hello Brian,
Happy New Year! Based on ArcGIS Survey123's documentation, the appearance setting supported for range question is the "no-tick" appearance.
Therefore, I believe posting this functionality request in ArcGIS Ideas might be the best course of action.
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
