Best way to open and edit existing surveys in web app with URL parameter
327
06-16-2025 10:35 AM
SFM_TravisBott
Hoping somebody can chime in and tell me whether or not I'm on a wild goose chase.
My issue:
I have a survey with nested repeats, one of which uses a search appearance to query a feature service and return options. When a survey is opened using url parameters (see this post and this post) it gets completely bricked - previous repeats that existed are wiped out. There is no calculation to fire, none of the previously recorded information, etc. Calculation mode is 'always' so it seems like this shouldn't be a problem.
I've tried it using arcade, as below:
var urlsource = 'arcgis-survey123://?';
var params = {
  itemID: '6c6ed14f3b9749f098b2e84c6d9ed18c',
  action: 'edit',
  'q:globalId': $feature.GlobalID,
  folder: 'inbox',
  update: 'true'
var url = urlsource + UrlEncode(params);
var incName = $feature.IncidentName
var surveyHTML = '<br><a href='+url+' style = "color:#1e90ff">Click to Launch Survey for '+incName+' Incident</a>'
return {
	type : 'text',
	text : surveyHTML //this property supports html tags
As well as just manually putting the URL together.
I have also tried just using this method:
https://survey123.arcgis.app/?itemID=6c6ed14f3b9749f098b2e84c6d9ed18c&action=edit&update=true&folder=*
....and it wipes out the custom map, even if being opened by the same person who performed the survey.
Is there a methodology that actually works for what I'm trying to accomplish? I have a few dozen users submitting some fairly complicated surveys. I'd like them to be able to open their surveys and edit them from a means other than the Sent folder on their device. Is this possible?
SFM_TravisBott
Yessir. The problem turned out to be I was not storing the URL that was used for the queries, so when an edited survey was opened it didn't have anything to reference for where to look. And because of the firing rules for a survey in edit mode it doesn't re-calculate for fear of overwriting an existing value, even if calculation mode is set to always. So the solution was to store the URL as an attribute so an edited survey could reference it.
DeonLengton
Hi there
Quick question - did you put AllowAdds / query in the esri::bind::parameters column of your repeats?
https://community.esri.com/t5/arcgis-survey123-questions/can-allowupdates-and-allowadds-in-esri-bind...
SFM_TravisBott
