Can AllowUpdates and AllowAdds in ESRI:Bind:Parameters be changed after a survey has been published?
1488
01-24-2019 10:26 AM
TimothyKing3
Hi all,
I have a daily summary form that I would like to have the ability to edit in the inbox in 123.  I set the ESRI:Bind:Parameters to allowUpdates=true and allowAdds=true but in the inbox i do not see the previous data that I would like to edit and can only update data via the Sent items.
Also once those are set can they be changed via 123Connect?
BrandonArmstrong
Hi Timothy,
Have you specified a query?  Try inputting the following into the bind::esri:parameters column of the 'begin repeat' row for the repeat that you would like to enable for editing...
query allowUpdates=true
TimothyKing3
Thanks Brandon!  That worked for me.
