Availavility Surveys in Desktop
921
09-26-2018 02:06 PM
BraulioGalvez1
Hi Survey123 Team!
I have a problem with Survey123 Connect. Unexpectedly, my surveys is not availables. I reinstall the survey connect v. 3.0.142, but without success.
I'm attaching the video with workflow of issue for your understand:Issue_Survey123
Thank you in advance!!!
Braulio.
BrandonArmstrong
Hi Braulio, that is interesting behavior.
Can you please capture a log file and upload to this thread?
Troubleshoot—Survey123 for ArcGIS | ArcGIS
Thank you,
Brandon
BraulioGalvez1
Hi Brandon Armstrong‌.
Thank you for your response. I'm attaching the log file. Is the correct?
Dropbox - Survey123ConnectforArcGIS-20180927-091329.log
I hope your comments and thank you in advance!
Ps: I still with the same problem today
Braulio.
BrandonArmstrong
Thank you for the log file, Braulio.
I'm wondering if you are able to successfully create a new survey after logging into Survey123 Connect?  Please try this and see if you are able to do so without error.
Brandon
BraulioGalvez1
Related with this, an user of Esri Staff recommended rename the folder where keep the surveys in desktop, then, will need download the surveys newly.
https://community.esri.com/message/807266-re-survey123-connect-not-connecting-to-mysurveydesigns-fol...
It should be noted that although I did this procedure, after a continuous time. I think there is an error in this version of survey connect (most recent).
I hope your comments and thank in advance
Braulio.
BraulioGalvez1
I found other user of Professional Services, in ESRI Chile, that has the same issue with survey123.
The version is latest.
Best regards.
Braulio.
