Attaching documents to a Survey123 form before publishing the survey?
1332
06-28-2020 04:31 PM
MoniqueDunning
Attaching documents such as safe work method statements, task procedures, manufacturer's manuals, etc.
DougBrowning
MVP Esteemed Contributor
No it is blocked.  Their is a lot of interest for them to open it up.  In Collector as well.  I do not know why it is blocked.
Note the web form can do it but this does not work offline then.
Please upvote
PDF Attachments and Excel config in Survey123
and see
https://community.esri.com/thread/234049-file-uploads-in-survey123-connect-form-building
CSVs would be huge for me!
DougBrowning
Just saw there is going to be more support in 3.10.  Not sure the specifics however.
Improved support for file question type (for attaching non-image files) on all platforms.
DougBrowning
Confirmed and tested that I can not add CSV files to 123 in v3.10!   Seems open to all files.
Thank you!
