Add Support for info/help bubbles to describe questions & domains
1883
07-24-2023 01:15 PM
Status: Open
Labels (3)
DevinJacobs_JGI
Looking for the ability to incorporate info bubbles into Survey123 to help further describe questions or guide users to select the appropriate domain for select questions. Using notes and/or grouping options to display additional help text for questions are both inadequate solutions and most survey applications allow for hover-text or click-to-view help text icons. The submission form to submit this request even has one (attached screenshot).
Within these help-text boxes, I'd like to be able to use html formatting so I can bold certain words, include line breaks, etc.
Thanks!
3 Comments
DataOfficer
Have you taken a look at guidance_hint functionality? It's not perfect (e.g. limitations on the number of lines), but it is in a similar direction to what you are asking for.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformessentials.htm#ESRI_SECTION1_5F128...
mattkramer
I would also be interested in this functionality. Not only would including a good amount of text in a pop-up be nice but embedding images in a pop up to show an example of what a certain answer to a select_multiple could look like would be very helpful.
PegGronemeyer1
As mentioned above, the guidance hint is somewhat helpful - my biggest thing with it is that people are looking for an "i" in a circle - the well-known information link popup.  could we change the icon?
