Error in Optimal Path as Line from Distance Accumulation with Vertical Movement Costs
2422
12-11-2021 11:54 PM
LaurenHolzman
I get this error (#010423) when I try and the optimal path function following the distance accumulation function with the optional cost associated with vertical movement. I do not get the error when running without the optional cost with vertical movement and am confused as to how the vertical movement costs are creating the error. Any help is appreciated. Thanks!
DanPatterson
MVP Esteemed Contributor
LaurenHolzman
The statistics that it calculates approach +/- infinity.
LaurenHolzman
Upon further inspection, it would appear that when calculating the distance accumulation raster and the back direction raster when there is cost associated with vertical movement, both are empty. Any ideas as to why this may be?
ElizabethGraham
Hi Lauren,
I am a Product Engineer on the Spatial Analyst team and work with the Distance tools. I would like to help resolve this issue. Can you please email at egraham@esri.com.
Thanks, Liz
