ArcGIS Runtime SDK for iOS Questions
Other Boards in This Place
Latest Activity
Sort/Filter :
POST
My dev device is an iPhone 15 ProMax with iOS 26. And the version for ArcGIS Swift SDK is 100.15.6.If I create a map ...
ZhouYi
by ZhouYi Emerging Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 11-04-2025
0 5
1719
POST
Hi,In a sample app with just a single map, I am trying to load a WMS layer with the next parameterslet wmsServiceURL ...
DanielGaston
by DanielGaston Emerging Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 10-30-2025
0 4
POST
Hello Esri team,I encountered a random crash in my iOS app using ArcGIS Runtime SDK.The crash log shows it happens in...
ZheWang66369
by ZheWang66369 Emerging Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 11-10-2025
0 2
POST
Hello,I am uploading an iOS app to TestFlight that uses the ArcGIS Runtime SDK for iOS.I received this error during u...
RoshaniBorse
by RoshaniBorse New Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 06-25-2025
0 1
POST
Hi, when uploading an app that uses ArcGIS Runtime 100.15.x to the App Store through Xcode, you now get the following...
EirikH
by EirikH Regular Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 04-22-2025
0 2
POST
I have  an application named Al Murshid on App Store, developed using Xcode 16.4 & Swift 5.4 and ArcGIS SDK for iOS 1...
AfrozAlam
by AfrozAlam Occasional Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 12-05-2024
0 3
POST
We have been getting a lot of crashes since updating our app to 100.15.6Exception Type: EXC_BAD_ACCESS (SIGSEGV)Excep...
RTC
by RTC Regular Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 10-16-2024
0 6
2715
POST
Hi all,I am trying to have a customized map callout without the callout "leader" (as shown in below picture). In the ...
JackyCai
by JackyCai Occasional Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 10-08-2024
0 2
POST
I am developing an application on Xcode 15.4 & Swift 5.4 using ArcGIS SDK for iOS. I am trying to access the below UR...
AfrozAlam
in ArcGIS Runtime SDK for iOS Questions Last Updated 07-27-2024
0 2
POST
I am developing an iOS app on Xcode 14.2 using Swift 5.7 and ArcGIS Runtime SDK for iOS 100.15. I am using a map serv...
AfrozAlam
in ArcGIS Runtime SDK for iOS Questions Last Updated 07-17-2024
0 5
2932
POST
I have an existing app that currently uses .freehandPolygon as the creation mode for its sketch editor (100.15.2). I ...
HawkMan
by HawkMan New Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 06-10-2024
0 1
POST
I'm using ARCGIS 100.15. I'm trying to use travel mode restrictions by adding height and weight restrictions. In iOS ...
RonFessler
by RonFessler New Contributor
0 2
POST
The client is trying to cover a specific area of the basemap with a customized shapefile and customized labels. The c...
Raneemtest
by Raneemtest New Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 07-30-2024
0 2
POST
Our customers are reporting that our app is freezing and then crashing. This seems to be happening with iOS 17.4  and...
RTC
in ArcGIS Runtime SDK for iOS Questions Last Updated 05-21-2024
0 6
2970
POST
Which SDK can be use for ArcGIS maps in IOS devices "ArcGIS Maps SDK for Swift" or "ArcGIS Runtime SDK for iOS", and ...
JyoshnaRani
by JyoshnaRani Emerging Contributor
in ArcGIS Runtime SDK for iOS Questions Last Updated 05-07-2024
0 3
115 Subscribers
