We have been getting a lot of crashes since updating our app to 100.15.6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Subtype: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
VM Region Info: 0 is not in any region. Bytes before following region: 4301357056
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 100618000-1006d4000 [ 752K] r-x/r-x SM=COW /var/containers/Bundle/Application/61CC2BA1-D693-4CB6-83CA-58828B94F532/MyApp.app/MyApp
Termination Reason: SIGNAL 11 Segmentation fault: 11
Terminating Process: exc handler [34576]
Triggered by Thread: 0
Kernel Triage:
VM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter
Thread 0 name: Dispatch queue: com.apple.main-thread
Thread 0 Crashed:
0 Runtimecore 0x1023d0c70 auto esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)>::invoke_callable_<esri::common::Signal<void (esri::geomodel::Layer_content const&, bool)>::notify(esri::geomodel::Layer_content const&, bool) const::'lambda'(esri::common::signal_detail::erased_target_base&) const>(void const*, esri::common::signal_detail::erased_target_base&) + 20
1 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
2 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
3 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
4 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
5 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
6 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
7 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
8 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
9 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
10 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
11 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
12 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
13 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
14 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
15 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
16 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
17 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
18 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
19 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
20 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
21 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
22 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
23 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
24 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
25 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
26 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
27 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
28 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
29 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
30 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
31 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
32 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
33 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
34 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
35 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
36 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
37 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
38 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
39 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
40 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
41 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
42 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
43 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
44 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
45 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
46 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
47 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
48 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
49 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
50 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
51 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
52 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
53 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
54 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
55 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
56 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
57 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
58 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
59 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
60 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
61 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
62 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
63 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
64 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
65 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
66 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
67 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
68 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
69 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
70 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
71 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
72 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
73 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
74 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
75 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
76 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
77 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
78 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
79 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
80 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
81 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
82 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
83 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
84 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
85 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
86 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
87 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
88 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
89 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
90 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
91 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
92 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
93 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
94 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
95 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
96 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
97 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
98 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
99 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
100 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
101 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
102 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
103 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
104 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
105 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
106 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
107 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
108 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
109 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
110 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
111 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
112 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
113 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
114 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
115 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
116 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
117 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
118 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
119 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
120 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
121 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
122 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
123 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
124 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
125 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
126 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
127 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
128 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
129 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
130 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
131 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
132 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
133 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
134 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
135 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
136 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
137 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
138 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
139 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
140 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
141 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
142 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
143 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
144 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
145 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
146 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
147 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
148 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
149 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
150 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
151 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
152 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
153 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
154 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
155 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
156 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
157 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
158 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
159 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
160 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
161 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
162 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
163 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
164 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
165 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
166 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
167 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
168 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
169 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
170 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
171 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
172 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
173 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
174 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
175 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
176 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
177 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
178 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
179 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
180 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
181 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
182 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
183 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
184 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
185 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
186 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
187 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
188 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
189 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
190 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
191 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
192 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
193 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
194 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
195 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
196 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
197 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
198 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
199 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
200 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
201 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
202 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
203 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
204 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
205 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
206 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
207 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
208 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
209 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
210 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
211 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
212 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
213 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
214 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
215 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
216 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
217 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
218 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
219 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
220 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
221 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
222 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
223 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
224 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
225 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
226 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
227 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
228 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
229 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
230 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
231 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
232 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
233 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
234 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
235 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
236 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
237 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
238 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
239 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
240 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
241 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
242 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
243 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
244 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
245 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
246 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
247 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
248 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
249 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
250 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
251 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
252 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
253 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
254 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
255 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
256 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
257 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
258 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
259 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
260 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
261 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
262 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
263 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
264 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
265 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
266 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
267 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
268 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
269 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
270 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
271 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
272 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
273 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
274 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
275 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
276 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
277 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
278 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
279 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
280 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
281 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
282 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
283 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
284 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
285 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
286 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
287 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
288 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
289 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
290 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
291 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
292 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
293 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
294 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
295 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
296 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
297 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
298 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
299 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
300 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
301 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
302 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
303 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
304 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
305 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
306 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
307 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
308 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
309 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
310 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
311 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
312 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
313 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
314 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
315 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
316 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
317 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
318 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
319 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
320 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
321 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
322 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
323 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
324 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
325 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
326 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
327 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
328 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
329 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
330 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
331 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
332 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
333 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
334 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
335 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
336 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
337 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
338 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
339 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
340 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
341 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
342 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
343 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
344 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
345 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
346 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
347 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
348 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
349 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
350 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
351 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
352 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
353 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
354 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
355 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
356 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
357 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
358 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
359 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
360 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
361 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
362 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
363 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
364 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
365 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
366 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
367 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
368 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
369 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
370 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
371 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
372 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
373 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
374 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
375 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
376 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
377 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
378 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
379 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
380 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
381 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
382 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
383 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
384 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
385 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
386 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
387 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
388 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
389 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
390 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
391 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
392 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
393 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
394 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
395 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
396 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
397 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
398 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
399 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
400 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
401 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
402 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
403 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
404 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
405 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
406 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
407 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
408 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
409 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
410 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
411 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
412 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
413 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
414 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
415 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
416 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
417 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
418 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
419 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
420 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
421 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
422 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
423 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
424 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
425 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
426 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
427 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
428 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
429 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
430 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
431 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
432 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
433 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
434 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
435 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
436 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
437 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
438 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
439 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
440 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
441 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
442 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
443 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
444 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
445 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
446 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
447 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
448 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
449 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
450 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
451 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
452 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
453 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
454 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
455 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
456 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
457 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
458 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
459 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
460 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
461 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
462 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
463 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
464 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
465 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
466 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
467 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
468 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
469 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
470 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
471 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
472 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
473 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
474 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
475 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
476 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
477 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
478 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
479 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
480 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
481 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
482 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
483 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
484 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
485 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
486 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
487 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
488 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
489 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
490 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
491 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
492 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
493 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
494 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
495 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
496 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
497 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
498 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
499 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
500 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
501 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
502 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
503 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
504 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
505 Runtimecore 0x102f88a1c esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 348
506 Runtimecore 0x102184168 esri::geomodel::Layer_content::set_is_visible(bool) + 144
507 Runtimecore 0x101d2480c RT_Layer_setIsVisible + 32
508 ArcGIS 0x10128e3d4 __30-[AGSLayer initWithRTCObject:]_block_invoke.22 + 96
509 ArcGIS 0x10135e7f4 visibilityChangedHandler + 116
510 Runtimecore 0x10201e938 std::__1::function<void (void*, bool)>::operator()(void*, bool) const + 48
