Frequent crashes on ios 15.4
8546
12
03-28-2022 08:36 AM
YoussefMAHERZI
Since the version 15.4 of iOS and iPadOS, we encounter many crashes while zooming on AGSSceneView with polygons on it.
Logs :
Execution of the command buffer was aborted due to an error during execution. Caused GPU Address Fault Error (0000000b:kIOGPUCommandBufferCallbackErrorPageFault)
Command buffer execution failed (code 3): Caused GPU Address Fault Error (0000000b:kIOGPUCommandBufferCallbackErrorPageFault)
YoussefMAHERZI
No problem.
We had the problem on 100.13 and we tried to update to 100.13.1, same problem.
The problems occurs systematically when we update the device to ios 14.5.
Nicholas-Furness
I'm sure that's a typo and you mean iOS 15.4 🙂
We are actively investigating this. At the moment there is no work-around other than to use an earlier version of iOS.
I'll reply here when we know more.
Nicholas-Furness
FYI: Here is a blog post about this crash.
I will accept it as the solution so it appears up front to anyone reading this post.
