App will not clear or refresh after first result
675
04-27-2021 10:03 AM
AllanLambert
Our developer created a parcel app with an address search.  After we search and find an address and arrive on the map, we wish to see info on neighboring parcels.  If we click on a neighbor and view it's info then return to the map, we're still centered on the initial parcel from the search.  The newly clicked on parcel should cancel/supersede the initial search.   The developer says it's a server issue or IIS and the engineers say it's in the code.  GIS guy in the middle. _app/scripts/WVS.Mvc.ParcelViewer.Scripts.MapManager and Layoutsettings could control a refresh but I don't know. I attached a pic flowchart of the steps below and the web folder structure. Hopefully a setting will be obvious to someone here. Thanks for looking.
Steps to follow in pic attachment: Link to site City of Hampton
  1. Enter 94 and Lincoln St and hit Search
  2. Click 94 Lincoln in the Results tab
  3. See that 94 Lincoln St is in Property Sheet, then click Map tab to view 94 Lincoln in Map
  4. Pop up shows 94 Lincoln correctly.  Click on different parcel in current Map to create new pop up.
  5. In new pop up, click on “View Property Details” to see Property Sheet for 84 Lincoln St (or any other parcel).
  6.  Click on Map tab to view what should be the pop up for 84 Lincoln St. But you're back to 94 Lincoln.  Click on any other parcel and repeat steps 5-6, it always returns to 94 Lincoln...unless you start a new search in Step 1.
