Our developer created a parcel app with an address search. After we search and find an address and arrive on the map, we wish to see info on neighboring parcels. If we click on a neighbor and view it's info then return to the map, we're still centered on the initial parcel from the search. The newly clicked on parcel should cancel/supersede the initial search. The developer says it's a server issue or IIS and the engineers say it's in the code. GIS guy in the middle. _app/scripts/WVS.Mvc.ParcelViewer.Scripts.MapManager and Layoutsettings could control a refresh but I don't know. I attached a pic flowchart of the steps below and the web folder structure. Hopefully a setting will be obvious to someone here. Thanks for looking.
Steps to follow in pic attachment: Link to site City of Hampton
- Enter 94 and Lincoln St and hit Search
- Click 94 Lincoln in the Results tab
- See that 94 Lincoln St is in Property Sheet, then click Map tab to view 94 Lincoln in Map
- Pop up shows 94 Lincoln correctly. Click on different parcel in current Map to create new pop up.
- In new pop up, click on “View Property Details” to see Property Sheet for 84 Lincoln St (or any other parcel).
- Click on Map tab to view what should be the pop up for 84 Lincoln St. But you're back to 94 Lincoln. Click on any other parcel and repeat steps 5-6, it always returns to 94 Lincoln...unless you start a new search in Step 1.
