Failed to Compute footprints
2023
6
03-20-2023 01:45 PM
johnpol
ArcGIS Reality Studio 1.0 Problem
I have the error: Failed to Compute footprints.
Details: Failed to project camera session poses.
I used a Match AT Prj, if I import this file in ArcGIS Pro extension, I won't have problems but in ArcGIS Reality Studio 1.0 fail. I cannot generate the dynamic ortho.
2 Solutions
CamiloCortes
Hello @johnpol,
Thank you for the inquiry. This error can occur if the supplementary ArcGIS Coordinate System Data is not installed.
Can you please confirm whether it has been installed on the computer you are using?
Could you also provide the horizontal and vertical coordinate systems specified?
Best,
Camilo
NicoBonnafoux
@johnpol , I corrected the link in Camilo's response, you should now be able to access it.
CamiloCortes
Hello @johnpol,
Best,
Camilo
johnpol
I don't have access to that webpage? Where I can download that file to try?
johnpol
Horizontal EPSG: 5347 and Vertical SRVN16 Argentina
NicoBonnafoux
johnpol
thanks
johnpol
Hello Camilo
That was the problem, I needed the supplementary ArcGIS Coordinate System Data.
Best Regards
Juan Polanco
