How to activate custom MapTool from a DockPane Button?
3937
02-15-2021 12:37 PM
nita14
I am struggling with activating a new MapTool item (point sketching on amap) from a button located in a custom Dockpane. Can you please direct me to some code samples or resources on how to do that?
Thanks!
adam
Wolf
by Esri Regular Contributor
When you implement a button (or tool) you have to define its 'id' in the config.daml file.  Usually the item template for buttons/tools will define an id for you.  It looks like this:
<tool id="CompReporter_AddCompBySelection" caption="AddCompBySelection"
      className="AddCompBySelection" loadOnClick="true" ...>
          <tooltip ... </tooltip>
</tool>
the 'id' in this case is:  CompReporter_AddCompBySelection
In the 'code behind' for your dockpane you can then use your tool (or button) just like any other ArcGIS Pro button (built-in or not) by using this snippet:
// use CompReporter_AddCompBySelection
IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper("CompReporter_AddCompBySelection");
if (wrapper is ICommand toolCmd)
  // if it is a tool, execute will set current tool
  toolCmd.Execute(null);
GKmieliauskas
nita14
Hi Gintautas,
Thank you for the answer. I believe that the link you mentioned is useful only to activate arcgis pro built-in MapTools. Is it correct?
Thanks!
Adam
GKmieliauskas
If I understand your question right then you can activate Esri, your or third-party tools the same way. As described in link. One thing which you need to know it is tool ID. Here is link for Esri tools ID:
https://github.com/Esri/arcgis-pro-sdk/wiki/ArcGIS-Pro-DAML-ID-Reference
If you can find Esri sketch tool which is useful for your workflow you can activate it. Otherwise your can create your own sketch tool.
Here is the link to related thread:
https://community.esri.com/t5/arcgis-pro-sdk-questions/how-do-i-activate-deactivate-a-maptool/td-p/8...
Wolf
</tool>
nita14
Thank you @Wolf and @GKmieliauskas for the guidance. It works ok now.
