Why has arcgis stopped being able to open the address file for geocoding?
760
04-03-2024 01:27 PM
Labels (2)
DanAllenhtn
It's been working fine.  Now it died,
==> Start executing of geocoding.GeocodeAddresses
Start Time: Wednesday, April 3, 2024 3:23:22 PM
Executing Geocode Addresses...
ERROR 000006: Could not open the address table.
Failed to execute (GeocodeAddresses).
Failed at Wednesday, April 3, 2024 3:23:23 PM (Elapsed Time: 1.26 seconds)
Error: 6 - Could not open the address table.
Error: -2147467259 - Failed to execute (GeocodeAddresses).
\What is causing this how do i fix itg?>
Robert_LeClair
Esri Esteemed Contributor
A few questions for you:
1.  What ArcGIS Pro are you using?
2.  What is the table format?
3.  Are you using Query Layers?
RobertCao
Hi @DanAllenhtn ,
It seems like this error is documented here. Where is your address table stored? Is it on your local drive or Network drive? If your address table resides on your network drive, can you try moving it to your local drive and test geocoding again?
Robert
