Why do my layers stop working?
2274
6
01-27-2021 06:44 AM
by Anonymous User
Not applicable
You can see the image I have attached here. The issue I am having is that sometimes when I open a map I created the layers won't work! There will be a red exclamation mark by the layer and it won't turn on. This happens to the layers I drew myself and with layers I georeferenced. I don't know how to stop this from happening. Any suggestions?
Robert_LeClair
Esri Esteemed Contributor
It sounds like you have a broken data link.  You can learn more about it here as well as how to resolve.  Good luck!
by Anonymous User
Not applicable
I thought the same thing. But I created these layers by drawing lines and polygons. I thought that wouldn't be an issue for a layer like that? For the georeferenced layers - I agree.
Robert_LeClair
Hmmm...are the lines and polygons graphic layers or a geodatabase feature class?
by Anonymous User
Not applicable
I originally created them in ArcGIS Online.
VincentLaunstorfer
Is your ArcGIS Pro session logged in to your ArcGIS Online as active portal? Just a guess...
VincentLaunstorfer
Would your layers stored in  a location (network?) currently not accessible by your project and/or machine?
Here are some tips to help:
https://www.esri.com/arcgis-blog/products/data-management/data-management/arcgis-pro-tips-5-tips-for...
