Use a polygon overlay to assign raster cell values
7283
7
12-02-2021 02:17 PM
Labels (2)
GJB
Hello, I am using Pro 2.8.3. I want to use a polygon shapefile (areas of bedrock outcrop) as an overlay to a raster (overburden thickness) in order to assign the overlain raster cells a particular value (zero where bedrock is at the ground surface). Any tips would be greatly appreciated!  Thank you.
DanPatterson
build the expression, I can't remember if the single quotes are needed around the raster names
Con('geo_bed_exp_raster',1.8, Con('Int_TopoToR_1' <= 25, 0.6, 0.0001))
which basically means
      if geo_bed.... has a value, assign the new one 1.8,
     if false
         if 'Int_TopoToR_1' <= 25  give it value 0.6  otherwise 0.0001
in general .... condition, True, False
of you can nest them   (condition, True, (condition, True, False))
... sort of retired...
DanPatterson
pay attention to converting the polygon shapefile to raster (eg cell size, alignment, extent, snap raster),
then use the Con tool to assign the poly-raster to locations where it is present and the overburden raster otherwise.
Con (Spatial Analyst)—ArcGIS Pro | Documentation
GJB
Thank you Dan. I am having trouble formulating the con expression - my expressions are not giving the desired output. Specifically, how to assign the poly-raster to locations where it is present? Any additional input would be greatly appreciated.  Thanks!
DanPatterson
I don't know what your polygon file looks like, but if it just indicates where something is, then you will get a raster having a value (which ever field you pick) where it is present and nodata where it isn't.  So if you have several classes in your polygon file, then you will end up with a raster representing those classes and the empty spaces (no observation or nodata) will be classes as such.
When you have your raster produced from the polygon file, then you can proceed, but if you need help with the Con statement, show what your raster names are and what you have tried in the con statement
GJB
Please reference the attached screenshot. The poly-raster is 'geo_bed_exp_raster' which shows where bedrock is exposed at the surface.  The overburden raster is 'Int_TopoToR_1' which shows depth to rock.  Ultimately, I want to create a new raster with a new field called Recharge, that is assigned a value of 1.8 where the poly-raster is present; 0.6 where Int_TopoToR_1 <= 25; and 0.0001 where Int_TopoToR_1 > 25. I think I'm having trouble seeing how to put together a con expression that includes two existing rasters and a new field.
DanPatterson
     if false
GJB
Thank you Dan!  Your solution was right on target.  I used this variation of the expression:
Con(Int_TopoToR_1 = 0, 1.8, Con((Int_TopoToR_1 > 0) & (Int_TopoToR_1 <= 25)), 0.6, Con(Int_TopoToR_1 > 25, 0.0001 ))
DanPatterson
Glad it worked out
