Updated to 2.3 unable to save new polygons while digitizing. No error code just message informing me it does not work.
Hi Scott,
I'll mention the same thing I said to Liam: Please open a case with Esri Technical Support. The phone number is 888-377-4575. Please let me know once you have an open case, or if you hit any roadblocks.
Liam didn't see the issue in another File Geodatabase. Do you see the same problem in different or newly created File Geodatabase?
Thank you,
-Scott
Hi Scott,
I did not have the same problem when I created a new/empty file geodatabase
so I think it is the same as Liam. I was also able to edit another feature
class (points anyway) from one of my preexisting databases.
Scott
Hi Scott,
Ok so that's good. We'd still like to get to the bottom of it. It's probably best if we work through a Support case, but here are the type of questions I would ask:
Thanks for any further insight.
-Scott
